Perhaps it's a question of semantics but I take your statement "...about 2 threads to clear the hole for the shank..." to mean that only 2 threads can be engaged. In the US and Europe, VW offered alloy wheels at the same time as steel wheels w/o having to change studs by using a 60 degree tapered cone seat lugnuts. That permits the conical section to have threads as well. So as even though there are less threads in the "hex part" as you wrote, the conical portion plus the hex section together make up more than the requisite 7.5 thread engagement.
Lugnuts in combination with washers would not be the same as a single piece lugnut as the washer has no threads and no threads to contribute to actually holding the wheel in place.
sent from my electronic leash
On Nov 27, 2011, at 3:56 PM, "Anette" <peterw1000@gmail.com> wrote:
> Phill, Yes they have a rounded top or cap however the mag when placed on the hub only allows about 2 threads to clear the hole for the shank. Perhaps there are thinner washers and this would get 3 more threads into the hex ?
> Its actually that the stud does not make it out far enough to purchase into the hex part of the nut so dont think it would matter what nut you used it would still not reach the hex so only relying on the shank???????? In a bag from burwin volkswagen Regards Pete
> --- In Syncro_T3_Australia@yahoogroups.com, plander@... wrote:
>> I need to see what your nuts look like.
>> It sounds like the old style round shaft type with a washer. Is that correct?
>> Phill
>>> However the nut setup is wrong in my opinion and these mags should be
>>> fitted with the longer stud kit as the first time i removed them all to
>>> check breakes etc the nuts appeared to break on removal and refit
>>> process about 3 from memory. However the van came with a bag of spare
>>> nuts so i believe this problem arose prior therefore the bag of spare
>>> nuts.
>>> On close examination the stud only tightens on the sleve of the nut and
>>> is not long enough to get purchase on the hex part ??? This causes it to
>>> fail and neatly crack perfectly where the hex meets the shank.
>>> Has anyone else noticed this and if so what did you do ?????
