I am a new member also and have a 89 trakka camper syncro with a VC
which is starting to show signs of locking. I would like to know if
there is a source of rebuilt VC's in australia. There is a lot of
information about them, and the problem of the liquid ageing, on
american Vanagon forums. I found a supplier in Belgium called busman,
the website is www.busman.be/ but I would prefer to deal with an
australian supplier if there is one. I would like to purchase one so
I can replace mine before it causes any damage.
Andy
--- In
Syncro_T3_Australia@yahoogroups.com, Michael Roberts
<type500@...> wrote:
> Thanks for that, I will look into it a bit more. I will put the
shaft back in and play around to see what happens.
> Michael
> ----- Original Message ----
> From: Les Harris <leslieharris@...>
> Sent: Wednesday, March 12, 2008 6:27:04 PM
> Subject: Re: [Syncro_T3_Australia] Where to get a New VC?
> Michael,
> It should try crawl over the blocks at a little above idle. Trying
to crawl over at idle is a sign of an aggressive VC but, as stated,
this is not necessarily a bad thing. If you are stalling the engine
when trying to do a full lock park, it is very aggressive, but still
not terminal. Terminal is when it is totally locked.
> From: Michael Roberts
> Sent: Wednesday, March 12, 2008 6:22 PM
> Subject: Re: [Syncro_T3_Australi a] Where to get a New VC?
> From what I have read, and the little I can under stand. I believe
the VC has become very aggressive. I have jacked up the back of the
syncro placed 2" block under the front wheels and at idle it is
tiring to crawl over the blocks. Hence I have removed the centre
driver shaft to prevent any drive line damage. Are VC available or
should I be looking for a decoupler. If so where do I look for a
decoupler?
> From: Les Harris <leslieharris@ optushome. com.au>
> Sent: Wednesday, March 12, 2008 5:49:32 PM
> Michael,
> There are varying degrees of 'going hard', and it is not always
detrimental. As the VC becomes more aggressive, it becomes
noticeable when doing full lock turns on a grippy surface - like dry
bitumen - and very noticeable in tight supermarket carparks. In
these circumstances, it pays to use the minimum speed possible to
reduce the load on the whole driveline.
> I have found that an aggressive VC actually improves cornering and
braking grip. A further side benefit of this is helping to
distribute braking forces, particularly on wet roads, and giving an
anti lock effect.
> The ideal solution is to fit a decoupler, which allows you to
decouple the drive to the front diff when parking but otherwise run
full time in all wheel drive.
> Sent: Wednesday, March 12, 2008 5:03 PM
> Subject: [Syncro_T3_Australi a] Where to get a New VC?
> I'm new to the Syncro scene and need to replace my VC as the old
one has gone hard. Where should I start looking? Is there any one in
Australia that is good for parts or should I be looking over seas?
> Be a better friend, newshound, and know-it-all with Yahoo! Mobile.
Try it now.
Try it now.
______________________________________________________________________
______________
> Looking for last minute shopping deals?
> Find them fast with Yahoo! Search.
http://tools.search.yahoo.com/newsearch/category.php?category=shopping
