--- In Syncro_T3_Australia@yahoogroups.com, greg esposito wrote:
> Bob you have hit the nail on the head here- "However I would be wary of overgearing - the Subi loves to rev!" The way the Ej25 is set up to run in late model subis (cams, FI, exhausts etc) is not to gain high torque at low rpms. You compare the performance of this engine in a modern car to this engine in a twenty year old flying brick at your detriment. My advise would always be do the engine install first. Then drive. If you think you want to change the ratio of a gear or final drive mimic this by fitting tyres of the right OD. Pulling out gearboxes to change ratios repeatedly can get very tiresome and expensive. Greg E
> From: Robert Turnbull bobtau01@...
> Sent: Tuesday, 11 June 2013 12:24 AM
> Subject: [Syncro_T3_Australia] Re: Which driveshaft decoupler?
> Â
> Hi Bruce,
> A couple of points re the EJ25 -Â
> 1. I found with mine, the standard ratios and 215 X 75R15 tyres gave a good balance between power and economy in 4th, but this was with loads and towing a camper trailer sometimes. However I would be wary of overgearing - the Subi loves to rev!Â
> 2. Partly because of the towing, but also because of the extra power of the Subi, I found the gearbox suffered when the decoupler put all the load on the rear wheels, so Rudi put the oiling plates and the extra spider gears in mine when he rebuilt it, suggesting I leave it in 4WD when towing.
> Anyway I am sure you will notice the difference when it is all installed, good luck!
> Bob Turnbull
> Â Â Â
hahahahahahahahah,ring and ask his brother see what he thinks,tell him I sent you.
BenC
--- In Syncro_T3_Australia@yahoogroups.com, "bruce.morphett" <bruce.morphett@...> wrote:
> Thanks Greg,By the way I spoke to Paul Muller yesterday & he quoted me
> $1850 to supply & fit a decoupler. Sounds reasonable. Also he takes my
> old nosecone. Mullers could be a good option for the trans rebuild too
> at the same time. Paul sounds like a VW traditionalist though. He didn't
> take to the idea of a Subaru donk in a T3 Syncro at all!.Bruce.
> to change ratios repeatedly can get very tiresome and expensive.Â
> Greg E
> > Â
> > Hi Bruce,
> when towing.
> > Bob Turnbull
> > Â Â Â
On 12/06/2013, at 11:29 PM, Ben wrote:Paul sounds like a VW traditionalist though. He didn't take to the idea of a Subaru donk in a T3 Syncro at all!.
BenC
> Greg E
> > Â
> > Hi Bruce,
> when towing.
> > Bob Turnbull
> > Â Â Â
Very handy.
Thanks also for the picture from your long weekend trip - I must revisit.
At 07:34 PM 12/06/2013, you wrote:
Just found this tyre size comparison between the 235 x 75 x 15 tyres
(which I have) compared to the 30 x 9.5 x 15 tyres I noticed Paul has on
his syncro.
They look the same size but clearly there is a bit of difference -
particularly the side walls.
http://www.tacomaworld.com/forum/tirecalc.php?tires=235-75r15-30-9.5r15
Very interesting the minor differences and what it means in relation to
the speedo readings.
He's done a few now
He quoted aprox 13k drive in and drive away.
Sent from my iPhone
On 13/06/2013, at 2:37 PM, Hartmut <hartis@live.com.au> wrote:
Heh Guys, happy that there are still fellas around the sort of Paul M. and why would I change my beautiful MV for something else ?? It's done 400 000 clicks without a hitch other than a reservoir cover, some thermostats, fan belts etc...The first 15 yrs it has always been serviced once a year by M&M but finally the drive to them got a bit long (900ks return) and I became a bit slack and did the service as best as I could. When stuck, one of the M's normally got us going again via phone link....For me the choice is MV , and btw , how many k's can I drive before having recouped the change- over investment ??HartOn 12/06/2013, at 11:29 PM, Ben wrote:Paul sounds like a VW traditionalist though. He didn't take to the idea of a Subaru donk in a T3 Syncro at all!.
BenC
> Greg E
> > Â
> > Hi Bruce,
> when towing.
> > Bob Turnbull
> > Â Â Â
Date: Thu, 13 Jun 2013 14:37:54 +1000
Subject: Re: [Syncro_T3_Australia] Re: Which driveshaft decoupler?
BenC
> Greg E
> > Â
> > Hi Bruce,
> when towing.
> > Bob Turnbull
> > Â Â Â
That's interesting. What's your fuel economy like with the VR6 (I am assuming it's the 2.8L VR6 from a '90's Golf)? How does it fit in the engine bay & under the hatch? How does it go with the Syncro gearing or have you got higher 3rd &/or 4th to suit?
Cheers, Bruce.
--- In Syncro_T3_Australia@yahoogroups.com, HamishD <dobson_hamish@...> wrote:
> Paul muller is the specific man who persuaded me to switch to a vr6.
> He's done a few now
> Sent from my iPhone
> > Hart
> >> BenC
> >> --- In Syncro_T3_Australia@yahoogroups.com, "bruce.morphett" <bruce.morphett@> wrote:
> >> > drive. If you think you want to changeà the ratio of a gear or final
> >> > to change ratios repeatedly can get very tiresome and expensive.Ã
> >> > Greg E
> >> > > Ã
> >> > > Hi Bruce,
> >> > > A couple of points re the EJ25 -Ã
> >> > overgearing - the Subi loves to rev!Ã
> >> > when towing.
> >> > > Bob Turnbull
> >> > > Ã Ã Ã
I had purchased a adapter plate / flywheel / clutch from Sherman for the 2.8 after speaking to Paul.
I currently have a 2.4 MV motor it gets 16l/100km and in town as a daily driver I'm disappointed with its drivability/ecu efficiency down low.
Hence the decision to acquire a 2008 r32 24 V vr6 for 6k with 60k km on the clock. I'm hoping its more efficient in town from a engine management point of view and then on the hwy a little more able.
I will be acquiring heavy duty albins 3/4 gears and getting a full drive live rebuild and I shall be installing a external oil pump / cooler recirculation circuit to maintain a improved transmission temperature.
Currently with my 2.4 I'm my specs are:
244 mm of tyres (22575r16)
Diff 6.17:1
Stock 1,2&3 gears + diesel 0.78 Vw forth.
Although I have increase swept engine capacity - the additions weight of a full camper and 16 l / 100....
Hence my path forward.
Yes u need a raised engine cover but my Westfalia rear bed sits 100 mm proud any way and all I currently store there is two collapsible chairs and anything extra that I dread removing when I need to get to my engine.
The fuel economy is poor now.
It will be poor with a vr6
It will always be poor because my Syncro resembles a big brick on wheels.
I simply wish to enjoy driving it a bit more.
Hamish
Sent from my iPhone
On 13/06/2013, at 5:33 PM, "bruce.morphett" <bruce.morphett@yahoo.com.au> wrote:
> Hi Hamish,
> Cheers, Bruce.
>> He's done a few now
>> Sent from my iPhone
>>> Hart
>>>> BenC
>>>>> Greg E
>>>>>> Â
>>>>>> Hi Bruce,
>>>>> when towing.
>>>>>> Bob Turnbull
>>>>>> Â Â Â
Bruce.
> I was going to use a 2.8 12v but the longer I looked the more the km the swap motor had - I couldn't see the point. I spent close to 10 k on my MV stroker and still not that impressed for daily driving. Great off road at 1000 rpm!!!
> Diff 6.17:1
> Hamish
> Sent from my iPhone
> On 13/06/2013, at 5:33 PM, "bruce.morphett" <bruce.morphett@...> wrote:
> > Hi Hamish,
> > Cheers, Bruce.
> > --- In Syncro_T3_Australia@yahoogroups.com, HamishD <dobson_hamish@> wrote:
> >> He's done a few now
> >> Sent from my iPhone
> >>> Hart
> >>>> BenC
> >>>>> Greg E
> >>>>>> Ã
> >>>>>> Hi Bruce,
> >>>>> when towing.
> >>>>>> Bob Turnbull
> >>>>>> Ã Ã Ã
> > Yahoo! Groups Links
I think that is why I'm partial to the vr6
Sent from my iPhone
On 13/06/2013, at 9:53 PM, "bruce.morphett" <bruce.morphett@yahoo.com.au> wrote:
> Thanks Hamish, hope you get more joy with the R32.
> Bruce.
>> Diff 6.17:1
>> Hamish
>> Sent from my iPhone
>>> Hi Hamish,
>>> Cheers, Bruce.
>>>> He's done a few now
>>>> Sent from my iPhone
>>>>> Hart
>>>>>> BenC
>>>>>>> Greg E
>>>>>>>> Â
>>>>>>>> Hi Bruce,
>>>>>>> when towing.
>>>>>>>> Bob Turnbull
>>>>>>>> Â Â Â
>>> Yahoo! Groups Links
Sent: Thursday, 13 June 2013 5:03 PM
Subject: [Syncro_T3_Australia] Golf VR6
Cheers, Bruce.
--- In mailto:Syncro_T3_Australia%40yahoogroups.com, HamishD <dobson_hamish@...> wrote:
> He's done a few now
> Sent from my iPhone
> > Hart
> >> BenC
> >> --- In mailto:Syncro_T3_Australia%40yahoogroups.com, "bruce.morphett" <bruce.morphett@> wrote:
> >> > --- In mailto:Syncro_T3_Australia%40yahoogroups.com, greg esposito wrote:
> >> > Greg E
> >> > > To: mailto:Syncro_T3_Australia%40yahoogroups.com
> >> > > Â
> >> > > Hi Bruce,
> >> > when towing.
> >> > > Bob Turnbull
> >> > > Â Â Â
--- In Syncro_T3_Australia@yahoogroups.com, alf ando wrote:
> Hi Bruce How are you going to work your speedo? are you staying with the original instrument?
> Alf
> From: bruce.morphett bruce.morphett@...
> Â
> Hi Hamish,
> Cheers, Bruce.
> --- In mailto:Syncro_T3_Australia%40yahoogroups.com, HamishD dobson_hamish@ wrote:
> > He's done a few now
> > Sent from my iPhone
> > > Hart
> > >> BenC
> > >> --- In mailto:Syncro_T3_Australia%40yahoogroups.com, "bruce.morphett" wrote:
> > >> > drive. If you think you want to changeÃâ the ratio of a gear or final
> > >> > to change ratios repeatedly can get very tiresome and expensive.Ãâ
> > >> > Greg E
> > >> > > Ãâ
> > >> > > Hi Bruce,
> > >> > > A couple of points re the EJ25 -Ãâ
> > >> > overgearing - the Subi loves to rev!Ãâ
> > >> > when towing.
> > >> > > Bob Turnbull
> > >> > > Ãâ Ãâ Ãâ
Sent from my iPhone
BenC
> Greg E
> > Â
> > Hi Bruce,
> when towing.
> > Bob Turnbull
> > Â Â Â
Sent: Friday, 14 June 2013 10:24 PM
Subject: [Syncro_T3_Australia] Re: Golf VR6
--- In Syncro_T3_Australia@yahoogroups.com, alf ando wrote: > > Hi Bruce How are you going to work your speedo? are you staying with the original instrument? > Alf > > > ________________________________ > From: bruce.morphett bruce.morphett@... > To: Syncro_T3_Australia@yahoogroups.com > Sent: Thursday, 13 June 2013 5:03 PM > Subject: [Syncro_T3_Australia] Golf VR6 > >  > > Hi Hamish, > That's interesting. What's your fuel economy like with the VR6 (I am assuming it's the 2.8L VR6 from a '90's Golf)? How does it fit in the engine bay & under the hatch? How does it go with the Syncro gearing or have you got higher 3rd &/or 4th to suit? > Cheers, Bruce. > > --- In mailto:Syncro_T3_Australia%40yahoogroups.com, HamishD dobson_hamish@ wrote: > > > > Paul muller is the specific man who persuaded me to switch to a vr6. > > He's done a few now > > He quoted aprox 13k drive in and drive away. > > > > Sent from my iPhone > > > > On 13/06/2013, at 2:37 PM, Hartmut hartis@ wrote: > > > > > > > > > > > Heh Guys, happy that there are still fellas around the sort of Paul M. and why would I change my beautiful MV for something else ?? It's done 400 000 clicks without a hitch other than a reservoir cover, some thermostats, fan belts etc...The first 15 yrs it has always been serviced once a year by M&M but finally the drive to them got a bit long (900ks return) and I became a bit slack and did the service as best as I could. When stuck, one of the M's normally got us going again via phone link.... > > > > > > For me the choice is MV , and btw , how many k's can I drive before having recouped the change- over investment ?? > > > Hart > > > > > > > > > On 12/06/2013, at 11:29 PM, Ben wrote: > > > > > >> Paul sounds like a VW traditionalist though. He didn't take to the idea of a Subaru donk in a T3 Syncro at all!. > > >> > > >> hahahahahahahahah,ring and ask his brother see what he thinks,tell him I sent you. > > >> BenC > > >> > > >> --- In mailto:Syncro_T3_Australia%40yahoogroups.com, "bruce.morphett" wrote: > > >> > > > >> > Thanks Greg,By the way I spoke to Paul Muller yesterday & he quoted me > > >> > $1850 to supply & fit a decoupler. Sounds reasonable. Also he takes my > > >> > old nosecone. Mullers could be a good option for the trans rebuild too > > >> > at the same time. Paul sounds like a VW traditionalist though. He didn't > > >> > take to the idea of a Subaru donk in a T3 Syncro at all!.Bruce. > > >> > --- In mailto:Syncro_T3_Australia%40yahoogroups.com, greg esposito wrote: > > >> > > > > >> > > Bob you have hit the nail on the head here- "However I would be wary > > >> > of overgearing - the Subi loves to rev!" The way the Ej25 is set up to > > >> > run in late model subis (cams, FI, exhausts etc) is not to gain high > > >> > torque at low rpms. You compare the performance of this engine in a > > >> > modern car to this engine in a twenty year old flying brick at your > > >> > detriment. My advise would always be do the engine install first. Then > > >> > drive. If you think you want to change the ratio of a gear or final > > >> > drive mimic this by fitting tyres of the right OD. Pulling out gearboxes > > >> > to change ratios repeatedly can get very tiresome and expensive. > > >> > Greg E > > >> > > > > >> > > > > >> > > ________________________________ > > >> > > From: Robert Turnbull bobtau01@ > > >> > > To: mailto:Syncro_T3_Australia%40yahoogroups.com > > >> > > Sent: Tuesday, 11 June 2013 12:24 AM > > >> > > Subject: [Syncro_T3_Australia] Re: Which driveshaft decoupler? > >
>> > > > > >> > >  > > >> > > > > >> > > Hi Bruce, > > >> > > > > >> > > A couple of points re the EJ25 - > > >> > > > > >> > > 1. I found with mine, the standard ratios and 215 X 75R15 tyres gave a > > >> > good balance between power and economy in 4th, but this was with loads > > >> > and towing a camper trailer sometimes. However I would be wary of > > >> > overgearing - the Subi loves to rev! > > >> > > > > >> > > 2. Partly because of the towing, but also because of the extra power > > >> > of the Subi, I found the gearbox suffered when the decoupler put all the > > >> > load on the rear wheels, so Rudi put the oilingplates and the extra > > >> > spider gears in mine when he rebuilt it, suggesting I leave it in 4WD > > >> > when towing. > > >> > > > > >> > > Anyway I am sure you will notice the difference when it is all > > >> > installed, good luck! > > >> > > > > >> > > Bob Turnbull > > >> > >    > > >> > > > > >> > > > > > > > > > > > > > > > >
Sent from my iPhone
On 15/06/2013, at 6:11 PM, alf ando <dansk53bus@yahoo.com.au> wrote:
So how is fitting a R32From: bruce.morphett <bruce.morphett@yahoo.com.au>
Hi Alf,My plan is to go to an Subie EJ25, hopefully in the next 12 months. Not sure, but I prefer to stay with the original. Not aware of any need to change. Cheers, Bruce.
--- In Syncro_T3_Australia@yahoogroups.com, alf ando wrote: > > Hi Bruce How are you going to work your speedo? are you staying with the original instrument? > Alf > > > ________________________________ > From: bruce.morphett bruce.morphett@... > To: Syncro_T3_Australia@yahoogroups.com > Sent: Thursday, 13 June 2013 5:03 PM > Subject: [Syncro_T3_Australia] Golf VR6 > >  > > Hi Hamish, > That's interesting. What's your fuel economy like with the VR6 (I am assuming it's the 2.8L VR6 from a '90's Golf)? How does it fit in the engine bay & under the hatch? How does it go with the Syncro gearing or have you got higher 3rd &/or 4th to suit? > Cheers, Bruce. > > --- In mailto:Syncro_T3_Australia%40yahoogroups.com, HamishD dobson_hamish@ wrote: > > > > Paul muller is the specific man who persuaded me to switch to a vr6. > > He's done a few now > > He quoted aprox 13k drive in and drive away. > > > > Sent from my iPhone > > > > On 13/06/2013, at 2:37 PM, Hartmut hartis@ wrote: > > > > > > > > > > > Heh Guys, happy that there are still fellas around the sort of Paul M. and why would I change my beautiful MV for something else ?? It's done 400 000 clicks without a hitch other than a reservoir cover, some thermostats, fan belts etc...The first 15 yrs it has always been serviced once a year by M&M but finally the drive to them got a bit long (900ks return) and I became a bit slack and did the service as best as I could. When stuck, one of the M's normally got us going again via phone link.... > > > > > > For me the choice is MV , and btw , how many k's can I drive before having recouped the change- over investment ?? > > > Hart > > > > > > > > > On 12/06/2013, at 11:29 PM, Ben wrote: > > > > > >> Paul sounds like a VW traditionalist though. He didn't take to the idea of a Subaru donk in a T3 Syncro at all!. > > >> > > >> hahahahahahahahah,ring and ask his brother see what he thinks,tell him I sent you. > > >> BenC > > >> > > >> --- In mailto:Syncro_T3_Australia%40yahoogroups.com, "bruce.morphett" wrote: > > >> > > > >> > Thanks Greg,By the way I spoke to Paul Muller yesterday & he quoted me > > >> > $1850 to supply & fit a decoupler. Sounds reasonable. Also he takes my > > >> > old nosecone. Mullers could be a good option for the trans rebuild too > > >> > at the same time. Paul sounds like a VW traditionalist though. He didn't > > >> > take to the idea of a Subaru donk in a T3 Syncro at all!.Bruce. > > >> > --- In mailto:Syncro_T3_Australia%40yahoogroups.com, greg esposito wrote: > > >> > > > > >> > > Bob you have hit the nail on the head here- "However I would be wary > > >> > of overgearing - the Subi loves to rev!" The way the Ej25 is set up to > > >> > run in late model subis (cams, FI, exhausts etc) is not to gain high > > >> > torque at low rpms. You compare the performance of this engine in a > > >> > modern car to this engine in a twenty year old flying brick at your > > >> > detriment. My advise would always be do the engine install first. Then > > >> > drive. If you think you want to change the ratio of a gear or final > > >> > drive mimic this by fitting tyres of the right OD. Pulling out gearboxes > > >> > to change ratios repeatedly can get very tiresome and expensive. > > >> > Greg E > > >> > > > > >> > > > > >> > > ________________________________ > > >> > > From: Robert Turnbull bobtau01@ > > >> > > To: mailto:Syncro_T3_Australia%40yahoogroups.com > > >> > > Sent: Tuesday, 11 June 2013 12:24 AM > > >> > > Subject: [Syncro_T3_Australia] Re: Which driveshaft decoupler? > > >> > > > > >> > >  > > >> > > > > >> > > Hi Bruce, > > >> > > > > >> > > A couple of points re the EJ25 - > > >> > > > > >> > > 1. I found with mine, the standard ratios and 215 X 75R15 tyres gave a > > >> > good balance between power and economy in 4th, but this was with loads > > >> > and towing a camper trailer sometimes. However I would be wary of > > >> > overgearing - the Subi loves to rev! > > >> > > > > >> > > 2. Partly because of the towing, but also because of the extra power > > >> > of the Subi, I found the gearbox suffered when the decoupler put all the > > >> > load on the rear wheels, so Rudi put the oiling plates and the extra > > >> > spider gears in mine when he rebuilt it, suggesting I leave it in 4WD > > >> > when towing. > > >> > > > > >> > > Anyway I am sure you will notice the difference when it is all > > >> > installed, good luck! > > >> > > > > >> > > Bob Turnbull > > >> > >    > > >> > > > > >> > > > > > > > > > > > > > > > >
