Hi All,
So I have only had my decoupler for a month or two now, new front locking diff and haven't driven that many kms. Probably not related? I have noticed a whine when doing 70+ km/h, slight in third, noticeable in fourth, only under load. Any suggestions on what this might be - is the gearbox going to need reconditioning or? A specific bearing or could be anything in there? Yet again I have also noticed one of the CVs with a slight click.
Thanks, Sam
Hi Christina,
Have just consulted the Owners Manual and it says that, not including the 16 inch wheels,
that all the wheels used on 2 WD & 4WD T3s are 5 1/2 J X 14 inch.
Although I have some recall that Syncro wheels are different to 2WD wheels,
but don't even though I have both,
don't know how they are different.
2WD tyre range:
175 R 14 6PR
185 R 14 6PR 99N
205/70 R 14 97 R
185 R 14 C6 PR99 N
205/70 R14 97 R
4 WD tyre range:
185 R 14 6PR 99N
205/70 R 14 97 R
205/70 R14 97 R
The most important things we need to consider apart from the wheel diameter, is the rim size range of any available tyres.
These days a lot of desirable tyres are made for rims much wider than ours.
The second thing is the load rating and as per the above ours is 97 plus.
The third thing depends on how serious we are with regard to off road.
If we are maily highway then ordinary car tyres will do,
but if we are seriously off road,
we need six ply with substantial side walls.
Lots of tyres cop punctured side walls when under compression the side walls are exposed to sharp objects.
Tyres that I have used:
My favourite, no longer available: Michelin 205 R 14 CPR6 105/103 XC 4S
Some years ago, I acquired a set of 15" wheels with the Toyo tyres like the ones on e-bay and one hot summer between Christmas and New Year, out around Narrabri in 40+ degrees conditions, on molten black top, three of them disintegrated within 50 Ks of each other. I normally travel with two spares, but this time it was a tow in to a camping area with cabins.
They were replaced on New Years Eve by 215/70 R15 C 109/107 Firestone CVH2000's by the Narrabri tyre dealer after a local picked them up for us from Dubbo.
You have to love country people !!!
I am currently looking at:
and both of these are for my 15" Mecedes Benz wheels:
Maxxis M8060 TREPADOR (RADIAL) http://www.maxxistyres.com.au/tyredetails.php?id=16&cat=4
Michelin Latitude Cross 205/70R15 http://www.michelin.com.au/Products-Services/Car-SUV-LT/suv/size.html?summer=Latitude%20Cross
I'd appreciate any intelligence on what others are using these days, but otherwise hope this helps.
--Original Message Text---
Date: Tue, 27 Aug 2013 04:16:28 +0100 (BST)
hi there,
some questions about tyres - can anyone help?
the sizes we can fit on our van are:
185 R14
205 R14
205/70 R14
ideally we would like all terrain tyres but the best quote we got was 235 $ per tyre - we are not rich enough for this so might go with 95$ per tyre for normal ones (Nixxon 205/70 R14). Are these normal prices? Anyone got any better ideas? we need new tyres to pass our rego....
Thanks Christina
Thanks for this Les,
This is possibly what Mark Hammond meant when he told me that the 2WD & 4WD wheels were different.
My problem is that this conversation was back in the early 90s, and these things a difficult to remember.
Hopefully Phil will read our E-mails and clear this up.
If they are 6" then it might open up the range of tyre choices.
Date: Wed, 28 Aug 2013 12:35:42 +1000
Peter,
Syncro Wheels: From memory, all Australian delivered Syncros came with 6 wheels. Phill will be able to give a definitive answer on that.
I'm running a set of Maxxis 751. 215/75r15. My second set. On previous posts I have recommended these tyres. I have changed my mind. This latest set is developing a lot of cracks in the side walls and one alarming split after about 20000km and 18months. The tyre deaer I bought them from said they were abused. They were not, just used for the purpose they were made for. The last set had 50000kn with plenty of life left when a side wall blow out meant replacing all 5. Anyway this is one tyre I beleave to have soft side walls and to avoid. Bill
