for those that think there is a big thing missing in their Syncro-Repair
life by not having a lift..
for whatever it is worth ..
I find that having the van nicely supported on truck-size jack stands, on a
smooth hard level floor..
and using a creeper to lay on ..
is very , very nice.
that way, I am laying on my back ..
I have my hands and arms right in front of me ...
and it's very nice to work on things.
with a lift.......
standing and working with my head tilted up to look pretty much straight
above me..
and my arms above my head...........forget it !
and ...half the time there's something 'up there' I need to undo
yet..
so it's either lower the van back down with the lift to be able to reach
that bolt on top of the engine..
or use a step lader to get up there..
and that's dangersous, and another thing to be in the way.
lifts are not better.
Full time professionals...........line mehcanices........where all they do
most of the day is work on cars on a lift..
they get tunel-carpel like symptoms sometimes...
or have trouble keeping good blood curculation to their hands ..
and they get just plain tired of having their hands above their heads
working on something.
I'd say a lift is handy for brake work ..
but's it right in front of you ..
but ...reaching way up there to deal with a starter ..
and you need tall stands to support the engine if you lower it some..
etc. Lift is not some magic cure-all.
scott
turbovans
southern oregon USA
working on cars nearly full time since 1964, about any kind you can name.
and VW's for 39 years.
Sent: Wednesday, August 31, 2011 6:56
PM
Solenoid/Starter Problem
The job had to be
done on a cold, windy driveway, which is very limiting compared with using a
hoist. I had to do everything flat on my back and this seriously
restricts accessibility. Given that my back is 78 years old and
has experienced many injuries from cycle racing, motorcycle racing, skiing and
other activities that the young and reckless (read senseless) pursue, the
access was even more difficult. Grumpy muttering flowed continuously
down the driveway and the Vietnamese family next door added a lot of new words
to their vocabulary.
I used a spray can
of degreaser on the solenoid/starter and on the inner CV joint so as to
minimize the amount of grot that would be dislodged. I removed the
inner CV and also removed the complete actuator assembly because I needed all
the access that I could manage. I removed the air cleaner and the
moulded hose to the manifold to get access to the top bolt from the engine
bay.
The nuts that held
the starter both had to be spannered all the way off. (Tip: when you
finally get them off, clean them well and run a tap through them.
If the bolt thread looks iffy, wire wheel them to totally clean the threads
and remove any burrs. On reassembly, the nuts then run on by
fingers only.)
Remove the battery
cable from the solenoid. Since the solenoid sits on top of the starter
and I couldnt clearly see the 50 terminal, I didnt disconnect that until I
had unbolted the starter itself. Because the coolant pipes are in
the way and because of the flat-on-78-year-old -working position, the amount
of wriggling necessary was enough to withdraw the starter; some of the
wriggling would have been up and down no doubt. It went back in much the
same way.
Under the
prevailing circumstances extremely difficult working position, having been
without the vehicle for nearly a week and using the mountain bike for local
shopping, I didnt even look at the bush. Once I established that
the starter ran instantly on the bench and since the end of the starter shaft
was evenly polished, I gave the bush a miss. Had the vehicle been
on a hoist, I would have drained the coolant system and dropped the two
coolant hoses the give enough access to also change the
bush.
The last root canal
issue was getting the battery cable and the 50 terminal back on, plus the new
push button lead. It is one of these cases of being able to see it or
being able to get a hand in but not both. This part of the process
is strictly Braille! Mercifully, the 50 terminal had a double
spade and there was thus one available for the push button cable.
The positive of the push button cable is a ring terminal that goes under the
battery cable. The flow is to the push button and circuit is made
to the 50 terminal when the button is pushed. It was probably this last
phase in which the Vietnamese people learned the most new
words.
There is an
outstanding issue that must wait until I get access to a hoist.
Somewhere back along the line, some ham fisted mechanic managed to break off
the nose of the vac actuator shaft inside the diff lock operating
shaft. This can easily be done when driving the roll pin
in. I have made up a tapered aligning rod that I will use to get
the roll pin right after I have been able to extract the broken
end!!
If you havent got
a hoist, take the root canal option any day!
[mailto: Syncro_T3_Australia@yahoogroups.com ] On Behalf Of Ken
Garratt
Sent: 01
September 2011 11:03
To:
Syncro _T3_Australia forum
Les,
Can you please briefly report on methodology used to
get the starter motor out, issues such as ....
*tilting down the motor or not, if not, what you
did
*removing the diflock actuator and its bracket or not,
if not, what did you do
*removal of the brass bush in the bell housing ...
method that worked
*any other "root canal surgery" issue you uncovered
along the way that may be worth noting
