engineers
You, me, & a few dozen others I know. I've even asked Herman. He said
something like maybe once his project is done. I suspect that is his
polite way of saying 'no'.
Sent from my non-WBX Syncro
On Jul 6, 2010, at 11:42 PM, plander@optusnet.com.au wrote:
> Herman can come and work on my car anytime!
>> BenT Syncro <syncro@gmail.com> wrote:
>> Try Herman's blog. Second paragraph:
>> http://vanagonsyncroproject-herman.blogspot.com/
>> BenT
>> Sent from my small booster
>> On Jul 6, 2010, at 11:16 PM, "bencroft96" <bencroft96@yahoo.com>
>> wrote:
>>> Scott,google bmw e30 brake booster vw t25.
>>> BenT, is this correct?
>>> --- In Syncro_T3_Australia@yahoogroups.com, "Mr Scott Pitcher"
>>> <spbconsulting@...> wrote:
>>>> Ben T,
>>>> Is there a great deal involved in changing over from a VW booster
>>>> to a BMW booster - especially seeing the booster is inside the
>>>> dash?
>>>> Do you have any steps for the replacement of the booster set-up or
>>>> any helpful tips?
>>>> Thanks,
>>>> Skot.
>>>> ----- Original Message -----
>>>> From: BenT Syncro
>>>> To: Syncro_T3_Australia@yahoogroups.com
>>>> Sent: Wednesday, July 07, 2010 2:34 PM
>>>> Subject: Re: [Syncro_T3_Australia] improved braking
>>>> Hi Les,
>>>> Sorry I have been offline most of the day today. Best place to get
>>>> info on converting a standard T3 Syncro is Davdi Marshall's site in
>>>> Canada. Here's the link:
>>>> http://www.syncro.ca/tech/audibrakes.htm
>>>> Keep in mind that Yurik's modification is for Syncro 16's as mine.
>>>> Our steering knuckle (aka suspension upright is designed to push
>>>> out the standard T3 calipers to clear the larger 276mm disc from
>>>> used on the Syncro 16. If you use the 276mm or 288mm Audi
>> 200/100/5000
>>>> Discs, the brake pads will sit 13mm off the edge of the disc. For
>>>> Syncro 16 owners, we simply move up to the Mercedes ML320-ML350
>>>> discs which are 303mm or the VW-Audi 312mm rotors.
>>>> Calipers are dual-pistons form the same Audi 200/100/5000 series
>>>> as mentioned in David's article. As Ben Croft just posted, there is
>>>> a carrier which not require machining. They are for single piston
>>>> calipers. Overland in California claims they are proprietary design
>>>> but close examination suggest they are nothing more than the
>>>> carriers from the SA big brakes (276mm) with a Audi A6 caliper. In
>>>> the end the larger diameter discs give you better braking via
>>>> larger swept area. With the dual -pistons, you get better pedal
>>>> feel as well.
>>>> Booster comes from any e30 BMW. In the US that is 1984-1991. My
>>>> former e30 was an 83 323i which had the same booster. Cost in the
>>>> US range from $50-$150 used.
>>>> Don't forget the 14" wheels will not fit these brakes. There are
>>>> some minor corrections concerning spacers for the calipers in
>>>> David's site. Email me if you decide to go this route. My total
>>>> cost was less than half the commercially available kits.
>>>> BenT
>>>> On Tue, Jul 6, 2010 at 8:54 PM, Les Harris <leslieharris@...>
>>>> wrote:
>>>> Hartmut,
>>>> From memory, Yurik's conversion was comprehensive and would have
>>>> included a matched booster. He has mentioned his conversion
>>>> previously but probably not in full detail. It will be worth
>>>> asking him for a detailed description.
>>>> Ben,
>>>> There are conversions that require some machining and some that
>>>> are bolt-on. Ben Tan in the US has good knowledge of what is
>>>> available and might be good enough to share it with us. Ben posted
>>>> detailed information some time ago but it would take some searching
>>>> to find it in the archives.
>>>> Les
>>> Yahoo! Groups Links
Les,I totally agree.I didnt know Herman or his site exsisted.The true ultimate Syncro.
> Ben,
> I can't tell you how impressed at what he has done. It awesome to see such
> workmanship!
> (Sent from my steam abacus)
> [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of BenT Syncro
> Sent: 07 July 2010 16:26
> Subject: Re: [Syncro_T3_Australia] Re: improved braking
> BenT
I believe, that was posted earlier. There are a couple of minor errors
re: clearance and spacers. That's David Marshall's site. He didn't
pioneer the modification but he popularize it in the English Language
Syncro forums.
That website predates Herman's blog by years. Just like my rear disc
project predated the Small Car kit by about a decade. SC brought the
system to people who would otherwise just dreamt about it. Now Burleysmotorsports.com
is making the caliper mounts and providing services to cut the rear
hubs.
Don't let anyone tell you drum brakes are then only way to get good
braking in the rear. Once upon a time, I discovered what happens when
you put too much braking in the back. Syncro swapped ends on the test
drive.;-)
Sent from my old brake drums
On Jul 6, 2010, at 11:48 PM, "bencroft96" <bencroft96@yahoo.com> wrote:
> my computer skills will never stop
> Thanx Turbovans
But, but, but, Ben... that's the link I sent which you just responded
to!
Hearing and echo. I suppose it's appropriate that you're a Ben too.
Sent from my dessert plate of plantains covered in syrup & sugar
On Jul 7, 2010, at 12:01 AM, "bencroft96" <bencroft96@yahoo.com> wrote:
> Computing skills still very,very dusty,sorry Skot
> thats beter
> --- In Syncro_T3_Australia@yahoogroups.com, "bencroft96"
>> Thanx Turbovans
>>>> BenT
No worries.
< burp >
'scuse me.
On Jul 6, 2010, at 11:41 PM, "Mr Scott Pitcher" <spbconsulting@bigpond.com> wrote:
Fanx again Ben T!
Sent: Wednesday, July 07, 2010 4:26 PM
>> Ben T,
>> to a BMW booster - especially seeing the booster is inside the dash?
>> any helpful tips?
>> Thanks,
>> Skot.
>> From: BenT Syncro
>> Hi Les,
>> used on the Syncro 16. If you use the 276mm or 288mm Audi 200/100/5000
>> feel as well.
>> BenT
>> On Tue, Jul 6, 2010 at 8:54 PM, Les Harris <leslieharris@...> wrote:
>> Hartmut,
>> Ben,
>> Les
I was just impressed by my new computer skills!Thanx BenT
> to!
> BenT
> > thats beter
> >> Thanx Turbovans
> >>>> BenT
I don't mean to downplay Herman's accomplishments but there a few other equally if not more talented Syncronauts out here. Sadly, none as talented at writing blogs as Herman.
Remember the thread about freewheeling hubs? I have seen Jack's highly modified Syncro in person. Longer wheelbase, aforementioned hubs, decoupler, big brakes, TDi, special bumpers, revised arches... too much to list as they say.
Sent from Les' sliderule
On Jul 7, 2010, at 12:14 AM, "Les Harris" <leslieharris@optusnet.com.au> wrote:
Ben,
I can’t tell you how impressed at what he has done.  It awesome to see such workmanship!
Hi all
I brought a set of brackets at the syncro 25 meeting, that then uses all T4 rear breaks, that is what most of them had fitted, and they are TUV approved, i am in the proses of fitting them at the moment .
Alf
Sent: Wed, 7 July, 2010 4:44:16 PM
Subject: RE: [Syncro_T3_Australia] Re: improved braking
Ben,
From: Syncro_T3_Australia @yahoogroups. com [mailto: Syncro_T3_Australia @yahoogroups. com ] On Behalf Of BenT Syncro
Subject: Re: [Syncro_T3_Australi a] Re: improved braking
http://vanagonsyncr oproject- herman.blogspot. com/
You learn something new everyday as I mentioned privately to Ben. So
now I find out about 'ducks nuts' in Oz. That's fantastic! Instead of
pate' you can have duck roe? Duckie oysters? OK, I looked it up.
Cheers, Ben C.
My tel# used to be 991-DUCK got an 'F' grade
On Jul 6, 2010, at 10:06 PM, "bencroft96" <bencroft96@yahoo.com> wrote:
> BenT,Bonza info.Looks like the ducks nuts.On to it now. who roo.
Alf,
It's the talk on the US Syncro forums that the rear disc from the T4's aren't up to the task of holding a heavy Syncro of steep grades vs. stock drum brakes.
Please post P/N if you can so I can crossreference with other VW models. I suspect they can come Passat's and such as well.
Sent from my VW powered device
On Jul 7, 2010, at 1:03 AM, alf ando <dansk53bus@yahoo.com.au> wrote:
Hi all
Alf
Hi again
caliper part no lucas 636873cn or 32326390/2
disk 701615601 or 3120503
Sent: Wed, 7 July, 2010 5:46:21 PM
Alf,
On Jul 7, 2010, at 1:03 AM, alf ando <dansk53bus@yahoo. com.au> wrote:
Hi all
Alf
Thanks,  Alf.
On Jul 7, 2010, at 1:37 AM, alf ando <dansk53bus@yahoo.com.au> wrote:
Hi again
Les,    I’m the proverbial stunned mullet, This doesn’t do any good to my already somewhat deflated self esteem...... Could it be that his father created Cuckoo Clocks in the Black Forest????
This creativity throws me...never seen anything like it...   Hartmut  (will have a sleepless night in my Camper, it’s my bedroom at present)
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of bencroft96
Sent: Wednesday, 7 July 2010 5:24 PM
Subject: [Syncro_T3_Australia] Re: improved braking
> Ben,
> workmanship!
> BenT
Big disc brake conversions for the syncro were available in Australia in 1990.
> Syncro forums.
> hubs.
> drive.;-)
> BenT
> > Thanx Turbovans
We are not talking about the SA style Big Brake kits but rather than
the dual-piston Audi caliper type.
> Australia in 1990.
>> errors
>> Syncro forums.
>> hubs.
>> drive.;-)
>> BenT
>>> Thanx
I think those SA ones came out later.
I'm talking about Oettinger.
> Phill,
> BenT
> > Australia in 1990.
> >> errors
> >> Syncro forums.
> >> hubs.
> >> drive.;-)
> >> BenT
> >>> Thanx
Winkler were selling SA parts as performance upgrades. I would not be surprised to discover that Oettinger did something similar. Companies such as Hansen sold Porsche 'big red' brakes adapted to T3's as well.
> Phill,
> BenT
> > Australia in 1990.
Oettinger did, mine has front and rear. i am not sure but paul muller was trying to convert the rear brakes on his dual cab so he took one of the roters to DBA aust to by some but they told him that it was not in their catalouqe and he stated that he Oettinger no longer supplied them, going to be interisting if i have to replace the rotors quess i will have to cross that bridge later
bob
Group,picked up my big BMW e30 booster today,and are looking into all options for bigger brakes on the front.Does anyone know if/or it is possible to convert T4 drums onto T3?
Also replaced timing belt,waterpump and all idlers on my EJ25 motor today.What a great little engine to work on.
> bob
Surely you mean T4 rear drums, right?Since most of the stopping duties
are done by the front brakes, it does not seem cost effective to do
anything with the rears. Besides a using a good quality rear brake
shoe, I would get the shoes arched to match the drums. I have found
that to be more than adequate for normal driving conditions.
Sorry, I have no experience with T4 drums. Coincidentally, I was at my
friend's shop yesterday and just came to the realization that some T4
models still ran with rear drums. From what I saw, they are larger
than T3 drums. Remember that T4's are FWD. There will likely be
differences in the hub section. I would imagine putting these drums on
a T3 would require adapting the backing plates which had ABS hubs
protruding on the backside. Too much work for little gain in my opinion.
