> yep ... mine had the black cap when I bought my syncro ...
> I wonder how come it hadn't failed and how come AutoBahn Strecker in
> Sydney never changed it during a routine service? After all, service
> receipts I have show they added "green" coolant concentrate at every
> service so they had to take the black cap off! Just how good are
> they??!!
> Date: Thu, 14 Jan 2010 10:20:10 +1100
> Subject: Re: Re: [Syncro_T3_Australia] Re: Coolant rubber hoses
> > The first thing I ever replace on a T3 is the pressure cap on the
> > coolant
> > reservoir - it's cheap insurance.
> This is a common cause of catastrophic hose failure. Make sure that you
> have the modified cap.
> Time for a new car? Sell your old one fast!
> http://clk.atdmt.com/NMN/go/157637060/direct/01/
> yep ... mine had the black cap when I bought my syncro ...Well, they're using green coolant. How good can they be?
> they??!!
On a side note, my former 1987 2.1 got a dose of fresh VW blue coolant
every couple of years. It managed 386K miles before I gave it up for
an engine conversion.
On 14/01/2010, at 12:46 PM, BenT Syncro wrote:On Jan 13, 2010, at 4:11 PM, Ken Garratt <unclekenz@hotmail. com> wrote:
> they??!!
Needless to say I've never darkened their front door.
Date: Wed, 13 Jan 2010 17:46:42 -0800
Subject: Re: [Syncro_T3_Australia] Re: Coolant rubber hoses
> they??!!
If It Exists, You'll Find it on SEEK Shopping Trolley Mechanic
Ask Bruce here from Rocky, he's got a diesel syncro.
Date: Thu, 14 Jan 2010 12:53:51 +1100
> they??!!
Start searching NOW! Search for properties that match your lifestyle!
On Wed, Jan 13, 2010 at 5:53 PM, Gary Cookson <gary@twentytwentyone.net> wrote:
Does anyone have any idea which coolant the diesels should run. Mine is in need of a change i think. What is in there looks decidedly murky?CheersGaryDiesels are not as finicky though the radiators are still aluminium. I have used regular non-phosphate coolant for my Diesel T3's and Mk1 Caddy & Golf Diesels without any corrosion concerns.BenT
On Wed, Jan 13, 2010 at 5:53 PM, Gary Cookson <gary@twentytwentyon e.net> wrote:
Sent from my T3 exhaust pipe
On Jan 13, 2010, at 7:15 PM, Gary Cookson <gary@twentytwentyone.net> wrote:
Thanks Ben, that's what i thought, cheersGaryOn 14/01/2010, at 2:09 PM, BenT Syncro wrote:Diesels are not as finicky though the radiators are still aluminium. I have used regular non-phosphate coolant for my Diesel T3's and Mk1 Caddy & Golf Diesels without any corrosion concerns.BenT
Sent: Thu, 14 January, 2010 10:20:10 AM
> The first thing I ever replace on a T3 is the pressure cap on theThis is a common cause of catastrophic hose failure. Make sure that you have the modified cap.
> coolant
See what's on at the movies in your area. Find out now.
Thanks for your active participation .... much appreciated here.
Yes well Tooley Imports at Waitara is more local for me than you, I've used them a bit in the past. I tested them once though, asked about pricing and availability of a T3 VC! .... haha, that was novel!
I totally agree with you about the major cause of WBX motor failures, usually following on from coolant system neglect or going awry on a trip. So for me my cooling system has always been a vexed question and how far should I go doing "preventative maintenance".
So far and without spending big dollars, I've at least gone over my cooling system and checked, cleaned out, repaired, reinforced the coolant hose system, not for the faint hearted but a useful learning curve. I agree with you though I should get a pressure test done on the radiator, thanks for the reminder. Not had a problem with it yet, don't know if it's the original. They usually fail at the least convenient time eh.
For a bit more "insurance", I've previously posted here about my adding 2 float switches, one to the expansion bottle and the other to the overflow bottle and wiring them in the engine bay to an audible piezo alarm. It has 2 different alarm soundings so I utilised both, one for each reservoir so when I hear an alarm sound, I know which switch has triggered. The expansion bottle float switch triggers the alarm for low coolant level meaning loss of coolant (triggers when level drops to half full), the overflow bottle float switch monitors too high coolant level (triggers when level goes above the "Maximum" level, meaning blowback of coolant into the overflow bottle, which can happen due to failing head gasket/s or pressure cap. Idea being, missing seeing the flashing light in the instrument cluster is all too easy and the common scenario for a cooked motor and big dollar repairs and a whole lot of inconvenience. Whereas to miss hearing an early warning audible alarm I find is is a lot harder and so stop asap. Occasionally I do check their functionality. I still try to remain attentive for the flashing light as well.
Sounds like I should at least check the oil cooler. I take it the oil cooler can be removed and inspected for integrity while doing an oil change. If so, is the seal (O ring?) reusable or is it a once only use type so I need to get a replacement first?
Thanks for the aussie $ hose pricing, gives me more A-B comparisons to help work out which way to jump with sourcing.
The question of stainless steel coolant pipes has been discussed at times on the US syncro forum. Some have researched this and come up with what they believe is better, I think perhaps a high grade flexible tubing ... possibly hydraulic hose? Not sure. BenT might have more current info on this.
Date: Wed, 13 Jan 2010 18:11:59 -0500
I started collecting all the coolant hoses about eighteen months ago to go with the engine and transmission rebuild [a work in progress]. I got most of them from Tooley Imports in Sydney, and the rest from Van Cafe, who have excellent photographs of the components on their website. I could have saved a few dollars buy buying the straight lengths of hose locally.
The rationale is that most wasserboxer engine catastrophes [that I have seen] are caused by coolant system failures, so there was no point fitting an expensive new engine without overhauling the cooling system.
The first thing I ever replace on a T3 is the pressure cap on the coolant reservoir - it's cheap insurance.
A part that is often overlooked is the 'oil cooler' which is connected to the water pump, and often corrodes. All of the metal pipes and fittings should be checked for corrosion [especially if the correct coolant has not been used] - Van cafe even sells some of them with ceramic coating.
Radiators should be cleaned and pressure-tested. I wouldn't even think about doing a big trip with a twenty-year- old radiator.
You are correct in saying that the hoses that fail the most are those closest to the engine.
I've include a few of the prices below; the hoses alone set me back over $500. Next time I probably wouldn't bother about the hoses that attach to the radiator, as they generally seem to last for ever. The Australian prices include GST, and the U.S. prices reflect what I paid in $AU at the time, but don't include freight - which would be difficult to compute because I bought a lot of other stuff as well. I didn't include the price of a water pump.
14/01/03 - Tooley's - 068 121 253D - Radiator T3 vanagon 1.9 - 2.1 1984-92 $313.50
14/01/03 - Tooley's - 025 121 321A - Radiator cap T3 vanagon 10.45
14/01/03 - Tooley's - freight on above [to Goulburn] 29.00
05/06/03 - Tom Hunt Spares - Triton TTG33Thermostat gasket 3.85
05/06/03 - Tom Hunt Spares - Triton TT273-180 Thermostat 59.55
26/05/05 - Tooley's - 6- 1.5 litre bottles G11 coolant 86.80
25/09/08 - Tooley's - coolant hose 025 121 058D oil cooler 4.20
25/09/08 - Tooley's - coolant hose 025 121 058E oil cooler to thermostat housing 8.30
25/09/08 - Tooley's - coolant hose 025 121 058G oil cooler 6.20
25/09/08 - Tooley's - coolant hose 025 121 058H to expansion tank 21.95
25/09/08 - Tooley's - coolant hose 025 121 058J at water pump 7.10
25/09/08 - Tooley's - coolant hose 025 121 058M cyl. head to plastic pipe 59.40
25/09/08 - Tooley's - coolant hose N 901 287 03 elbow to water pump pipe 14.85
25/09/08 - Tooley's - coolant hose 025 121 072A 4WD pl. junction pipe to motor 74.80
25/09/08 - Tooley's - coolant hose 025 121 073H pipe to thermostat housing 24.20
25/09/08 - Tooley's - coolant hose 025 121 081G 133.20
25/09/08 - Tooley's - coolant hose 251 121 083H radiator to main pipe 43.05
25/09/08 - Tooley's - coolant hose 251 121 102 plastic junction to main pipe 59.85
25/09/08 - Tooley's - coolant hose 025 121 108E to expansion tank 25.30
20/5/09 - Clark Rubber - 1.5 m. 5/16 [8mm] heater hose 15.50
31/7/09 - Van Café - 025 121 058 B Thermostat housing to pipe hose 30.00
31/7/09 - Van Café - 251 121 082 coolant pipe to radiator feed hose 27.00
31/7/09 - Van Café - 068 117 021 B Oil Cooler 80.00
28/8/09 - GoWesty! - Syncro coolant pipe repair kit [useless waste of money] 54.50
28/8/09 - GoWesty! - freight on above 30.00
By the way, has anybody out there found a local manufacturer for stainless steel coolant pipes?
Sell your old one fast! Time for a new car?
To: Syncro _T3_Australia forum <syncro_t3_australia@yahoogroups..com>
Sent: Thu, 14 January, 2010 11:11:29 AM
Subject: RE: [Syncro_T3_Australia] Re: Coolant rubber hoses
I wonder how come it hadn't failed and how come AutoBahn Strecker in Sydney never changed it during a routine service? After all, service receipts I have show they added "green" coolant concentrate at every service so they had to take the black cap off! Just how good are they??!!
Subject: Re: Re: [Syncro_T3_Australi a] Re: Coolant rubber hoses
> coolant
Sent: Thu, 14 January, 2010 10:59:42 AM
Roger,
I have copied the text of your email into the Files section because it is an excellent resource.
From: Syncro_T3_Australia @yahoogroups. com [mailto: Syncro_T3_Australia @yahoogroups. com ] On Behalf Of Gullyraker@aol. com
Sent: 14 January 2010 10:12
Subject: Re: [Syncro_T3_Australi a]
Date: Wed, 13 Jan 2010 20:19:10 -0800
To: Syncro _T3_Australia forum <syncro_t3_australia @yahoogroups. .com>
Subject: RE: [Syncro_T3_Australi a] Re: Coolant rubber hoses
> coolant
Browse profiles for FREE View photos of singles in your area!
On Jan 13, 2010, at 8:16 PM, Ken Garratt <unclekenz@hotmail.com> wrote:
.... a high grade flexible tubing ... possibly hydraulic hose? Not
As far as I know, stainless is the way most people are going. The long
plastic pipes have been coming from SA all these years. Mow I
understand the supply is very low and NLA in some markets. There are
now 2-3 competitors in the SS pipe market. The Germans are making
their own version which I believe GoWesty and possibly, VanCafe is
offering. I know the importer personally. I am not sure where BusDepot
gets their pipes. A privateer called Terry Kay on Illinois has been
making SS replacement pipes earlier than the commercial vendors as far
ad I know. He sells one and two piece kits as the other vendors. He
even offers a higher grade SS up to foodgrade. Seems a bit overkill to
me.
Unitially, all these vendors differed in how the ends are done.
Thankfully, they all seem to be have moved to the ridges ends which
holds the hose clamps better.
Beside the pumps, there is a group buy being organized to manufacture
silicon hoses. Right now the focus is on inline-3 powerplants like the
TDI. Given enough demand they may offer to WBX hoses as well.
I forgot to say before.
I discovered soon after I bought my syncro that I had the corrosion damage to the end of one of the plastic coolant pipes, I would imagine it was the hot feed line, can't remember, it's been a few years now since I tackled the problem. Typically it's the end lip or ridge that comes away due to metal corrosion, making it difficult to then keep the adjoining front coolant hose attached ... without the lip, the hose clip can pretty much just slide off as well as the hose .... bye bye coolant and you have a major problem. Also begs the question, how come they used ordinary steel in the pipe ends?
Anyway I saw that GoWesty repair kit and bought it, I mean, what other option did I have? Anyway, using bits out of the kit and double clipping the rubber hose/plastic pipe connection ... to this day I've never had a problem with it. Changing to the correct G12 plus coolant is probably helping as well, the previous coolant was green and there was a lot of metal corrosion particles in the pipes ...... bit of a worry at the time thinking about corroded head studs too.
Maybe you should revisit this option, be a lot cheaper.
Learn how Video chat with Windows Live Messenger
> Michael Rayner <mrayner51@yahoo.com> wrote:
> What's the modified cap? What's the difference and what can go wrong.
> Regards
> Michael
> > coolant
> _________________________________________________________________________
> _________
> See what's on at the movies in your area. Find out now:
> http://au.movies.yahoo.com/session-times/
> even offers a higher grade SS up to foodgrade.That is not good, Food grade is the least corrosion resistant.Marine grade is better.
> Anyway I saw that GoWesty repair kit and bought it, I mean, what otherThanks Ken for info on that. It may be worth having the kit for emergencies.
> problem with it.
> Cheers
> Gary
> > On Jan 13, 2010, at 4:11 PM, Ken Garratt <unclekenz@hotmail.com>
> > > they??!!
> > > Ken
> > Cheers,
> > BenT
