Prestige AC system
For recording here on the forum for members future reference, could you please supply the business name, contact details for this Milperra outfit. Ta.
Date: Fri, 25 Nov 2011 18:55:03 +1100
Subject: RE: [Syncro_T3_Australia] Re: Prestige AC system
The other supplier with the taller vents is a auto frost system, these guys still exist and still retro fit units into T3’s at Milperra ask for Geoff Thomas, I suggest to try and use an over head unit as the dash units are VERY noisy and have a less than desirable air flow in comparison.  Cheers steve
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Ben
Sent: Friday, 25 November 2011 6:48 PM
Subject: [Syncro_T3_Australia] Re: Prestige AC system
Hart,its all yours.See you soon.
BenC
> Thanks Ben, I'll gladly take it..!!!! Hartmut
> Sent: Thursday, 24 November 2011 10:06 PM
> I have Prestidge AC,and I have the same AC vents as Yurik and Ken.
> I hope to get my AC running before Xmas.Yuriks comments on his AC, has given
> me hope that one day,I may be able to drive in coolness and
> peacefulness(whingingless).
> BTW,I have a Prestidge compressor if someone wants one.
> BenC
> <mailto:Syncro_T3_Australia%40yahoogroups.com> , Ken Garratt <unclekenz@>
> wrote:
> > My on-dash unit looks the same as Yuriks. I have seen taller units in
> other syncros, don't know though what brand of install they are. Ken
> > From: gregespo73@
> > Date: Thu, 24 Nov 2011 01:51:07 -0800
> > Subject: Re: [Syncro_T3_Australia] Prestige AC system
> > Thanks for chiming in Yurik. I thought you might have that vent. Does the
> cabin temp come down as much as in a modern car? Or is it more like it
> brings it down to a bearable level? I might have a go at opening up the
> vents or adding one through the ashtray like the U.S. behr systems had. Greg
> E
> > From: Yurik Orlowsky <yuriko@>
> > Sent: Thursday, 24 November 2011 7:02 PM
> > Subject: RE: [Syncro_T3_Australia] Prestige AC system
> > GregMy Prestige ac probably has more air flow as the unit sits on top of
> the dash and has 5 vents blowing into the cabin. See attached photo of the
> unit, with red Kimberly dust in the vents from our recent trip to the
> NW.Yurik From:
> <mailto:Syncro_T3_Australia%40yahoogroups.com> ] On Behalf Of greg esposito
> > Sent: Thursday, 24 November 2011 2:25 PM
> > Subject: Re: [Syncro_T3_Australia] Prestige AC system Ken, I have a
> "modern" compressor. The system was retrofitted to r134a in 2008. The air
> temp is a constant 1-3 degrees at the vents. If there was a fault with my
> system it just would not cycle consistanty at this temp. There is just not
> enough air coming out to cool the cabin. Mark was telling me at the dotvw
> that he had a rear evap fitted. Does
> > Yurik/yourself have the big vent box on top of the dash? Mine employs the
> original face vents plus only one extra face vent in the middle of the dash
> next to the radio. It is possible Yuriks has more air flow than mine. Also I
> have not made any attempt to seal the cabin (carbon monoxide vent and fridge
> vent). I think alot of the cold air escapes or is diluted through these air
> leaks. I think the curtain is a no brainer if you dont have rear passengers
> why cool the rest of the cabin? I am not trying to put you off your project
> just saying after you get your standard presige system working you may need
> to do some extra work to make it comfortable in the cabin. Good luck. Greg E
> From: Ken Garratt <unclekenz@>
> > To: _T3_Australia forum Syncro <syncro_t3_australia@yahoogroups.com
> <mailto:syncro_t3_australia%40yahoogroups.com> >
> > Sent: Thursday, 24 November 2011 4:01 PM
> > Subject: RE: [Syncro_T3_Australia] Prestige AC system Greg,I presently
> can't agree with your contentions, except for the idea of a curtain behind
> the front seats. Graham Adams has installed one, apparently works
> > well. I'm happy to give the refurbishment a try, encouraged by a detailed
> post in 2008 from Yurik in Perth, as follows ...... Ken,My syncro has the
> Prestige Auto Air system and I also found it to be ineffective.
> > At one point when a re-gas was needed, I had the XT valve replaced and
> this improved the cooling significantly. Later when I did the Subaru engine
> conversion the new engine (2003) came with a compressor which was retro
> fitted to the existing system and this combination produced very crisp cold
> air, a huge improvement. I have come to the conclusion that the old
> compressors are inefficient and the modern new ones are the answer to an
> aging ac system that we have. One of my friends replaced his compressor in a
> 2L air cooled VW bus with a smaller modern one and it transformed his ac.
> With the T3, the engine compressor bracket would have to be modified and new
> hose connectors installed to suit the compressor used. All other components
> > remain.If you can get a new modern compressor that bolts straight on the
> existing bracket then that would be the major part of the ac upgrade. The
> remaining things are to get new fittings on the hoses to connect to the
> compressor, new TX valve and receiver-drier. I would use Hose Masters/Enzed
> or similar to crimp on new o-ring connectors. Any decrease of length as the
> result of cutting off the old fittings can be made up by using longer Al
> tails on the new fittings, all available off the shelf. The rest of the
> components in the system are re-used i.e.,
> > condenser, evaporator, thermostat, pressure switch and hoses.I would then
> present the completed system to an ac specialist and ask them to do a
> re-gas. Make sure that the system is flushed to remove any R12, oil and
> contaminants. Have a pressure test using Nitrogen gas and as well, a vacuum
> leak down test. Make sure they use extra oil because of the longer hoses in
> the syncro. They will probably inject a UV sensitive dye with the R134A for
> leak checking post re-gas. It would be a good idea to return to them after
> approx. 600km with good use of the ac for a further leak test.My ac has
> remained very cold now some 3yrs later. However one would expect a slow
> reduction of efficiency after 5yrs or so due to the slow molecular diffusion
> of the gas through the long rubber hoses and seal leaks. For the moment I am
> keeping cool. Regards Yurik 21/11/2008 So thanks very much again Yurik.This
> leaves me then with my original questions the subject of this post, if
> anyone has something specific to add along those lines, I'd
> > much appreciate it asap. TIA. Cheers.
> > KenTo: Syncro_T3_Australia@yahoogroups.com
> > From: gregespo73@
> > Date: Wed, 23 Nov 2011 19:47:13 -0800
> > Ken unless you are putting an air curtain behind the driver or an
> additional evaporator in the rear, save your money. The evaporator size and
> fan capacity are just insufficient for a five metre long box. If the in dash
> thing would have worked VW would have done it. Instead they put a massive
> duct from rear to front. I guess your lucky as from what I understand you
> probably won't have rear passengers which to me says go the
> > plastic curtain. Greg E From: Ken Garratt <unclekenz@>
> > Sent: Thursday, 24 November 2011 1:06 PM
> > Subject: [Syncro_T3_Australia] Prestige AC system All, I am about to
> embark on the refurbishment of the erm ... "much loved" Prestige AC system
> in my syncro. Touch wood. Wish me luck. Please see the attached files re the
> new Zexel compressor that will be swapped in for the 20yo Sanden 709 as well
> as the pdf fluid volume spec files for Vanagon AC systems. I suspect these
> Vanagon fluid volumes are not relevant to our Prestige AC system, merely
> notable. Agreed?
> > One thing I am unsure of is, aside from the refrigerant oil already in the
> new compressor, how much extra total volume of same refrigerant oil is added
> to the system for other components during refurbishment? Putting the
> question another way, ignoring the refrigerant oil volume included in any
> new compressor, how much extra total volume of same refrigerant oil was
> added to the system for other components during assembly as specified for
> the original Oz Prestige AC system in our vans? TIA. Cheers. Ken
Is yours a Prestige system?
Same same but different. Not fitted by prestige but has roughly the same parts. The switch is in the front locker spot and the thermostat is mounted under the dash behind the glove box. Which I think is the right place for it.
So Ken you have inspired me to give mine a crack too. As I said before all the hard work has already been done, I just need to increase the air flow. Yesterday I had a look at the vents. The left and additional centre vent come straight out of the evaporator. They only had a 1.5" hole in the evaporator case, I have opened up the hole to the size of the vent, about 2"x3". I also need to sort the tubing to the right had vent which I left out when I fitted the 10" brake booster as it did not fit. I will try and add a "T" piece at the ashtray hole and fit another vent there on my dash tidy. Its never going to be the a/c system the bus needs but hopefully this might make it worth turning on. Greg E
Sent: Friday, 25 November 2011 8:17 PM
Ok thanks for that, I'll be experimenting for a while, see how it goes.
So far I've only done a stationary thermometer check after I got home, right now though I have my doubts it'll pull down to the sort of low temps you are suggesting. Hence the query to other Prestige system users. Is yours a Prestige system?
Date: Thu, 24 Nov 2011 20:14:00 -0800
Ken, you should be able to use the thermostat knob to get the vent temp a couple degrees above freezing. If you feel it go warm and then cold again it has frozen up, so go hotter. Usually you can hear the thermostat cutting the clutch in and out. The clutch will usually cut in roughly between 5-7c and cut out between 1-4c. It can be a fine adjustment and also worth driving with the thermometer at the vent as sometimes after adjusting it stationary it will freeze on the road due to the increased air flow. Greg E
Sent: Friday, 25 November 2011 2:54 PM
All,
Well the AC is now functioning, all work completed in 1.5 hours. But I accept it is early days still.
I now need to trial it for some time, see how it goes, check temp, check sight glass, try it on a hot day etc etc. It has dye added, so later I can have it rechecked for leaks etc etc.
Changing over to a modern compressor as i did, anyone worrying about the necessity of swapping out obsolete flare type to current O ring type AC hose fittings "in car" need worry no more ... as they say, it was a piece of piss getting the hose fittings changeover done and done easily. Just need to find the person with the right equipment.
I think it'd be be a useful exercise for all those here who have a working Prestige AC system to carry out a simple temp test using a thermometer held in place right up against (NOT inside) the left-side vent of the dash unit with the system on high on both temp and fan and report your best recent result here. Such real life information would help determine roughly what temp drop output is possible based on these results, gives all of us a best temp benchmark and hence some clue as to whether or not any further AC system investigation or servicing is worthwhile/needed. Any starters please? This is all about helping each other ok.
On the comparitive costs of maintaining a 22 year old Syncro and a 23 year old Range Rover, the Range Rover is cheaper to buy parts for [if you shop around] but there are a lot more of them when you count electric windows, mirrors, sunroofs and central locking.
  I rebuilt the AC on the Rangie without too much trouble, but I still haven't  finished it on the Syncro. Been three summers now since I started ...
Roger Beetle.
Did a google search.
Sent: Friday, 25 November 2011 10:37 PM
BenC
> BenC
> > From: gregespo73@
> E
> NW.Yurik From:
> > From: gregespo73@
> notable. Agreed?
Hey Greg, my system does this. The thermostat cuts out just as things start to cool down & then the air seems to warm before it starts the cooling procedure again. I wander if it's freezing & thawing or if the thermostat is faulty & able to be adjusted. I think the system would work a lot better if this cutting out could be elininated and was able to pump out a continuous flow of cold air. Any thoughts?Eddie Bergodaz.
> From: Ken Garratt <unclekenz@...>
> Â
> All,
> From: hartis@...
> Date: Fri, 25 Nov 2011 09:16:21 +1100
> Â
> Ken, you have seen mine 2 weeks ago, it is Prestige and has 3 vents and is taller than yours....I took the cover off the other day and found that the evaporator had some sort of foam cloth (pollen filter ?) installed at at the air exit side. I have taken that thing out as it (to me) doesn’t serve any other purpose then obstructing the airflow. Worx better now. Hartmut
> Â
> From:Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Ken Garratt
> Sent: Thursday, 24 November 2011 9:09 PM
> Â
> Â
> My on-dash unit looks the same as Yuriks. I have seen taller units in other syncros, don't know though what brand of install they are.Â
> Â
> Â
> From: gregespo73@...
> Â
> Â
> Thanks for chiming in Yurik. I thought you might have that vent. Does the cabin temp come down as much as in a modern car? Or is it more like it brings it down to a bearable level? I might have a go at opening up the vents or adding one through the ashtray like the U.S. behr systems had. Greg E
> Â
> From:Yurik Orlowsky <yuriko@...>
> Â
> Greg
> My Prestige ac probably has more air flow as the unit sits on top of the dash and has 5 vents blowing into the cabin. See attached photo of the unit, with red Kimberly dust in the vents from our recent trip to the NW.
> Yurik
> Â
> From:Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of greg esposito
> Â
> Â
> Ken, I have a "modern" compressor. The system was retrofitted to r134a in 2008. The air temp is a constant 1-3 degrees at the vents. If there was a fault with my system it just would not cycle consistanty at this temp. There is just not enough air coming out to cool the cabin. Mark was telling me at the dotvw that he had a rear evap fitted. Does Yurik/yourself have the big vent box on top of the dash? Mine employs the original face vents plus only one extra face vent in the middle of the dash next to the radio. It is possible Yuriks has more air flow than mine. Also I have not made any attempt to seal the cabin (carbon monoxide vent and fridge vent). I think alot of the cold air escapes or is diluted through these air leaks. I think the curtain is a no brainer if you dont have rear passengers why cool the rest of the cabin? I am not trying to put you off your project just saying after you get your standard presige system working you may need to do some
> Â
> From:Ken Garratt <unclekenz@...>
> Â
> Greg,
> I presently can't agree with your contentions, except for the idea of a curtain behind the front seats. Graham Adams has installed one, apparently works well.
> Â
> I'm happy to give the refurbishment a try, encouraged by a detailed post in 2008 from Yurik in Perth, as follows ......
> Â
> Ken,
> My syncro has the Prestige Auto Air system and I also found it to be ineffective. At one point when a re-gas was needed, I had the XT valve replaced and this improved the cooling significantly. Later when I did the Subaru engine conversion the new engine (2003) came with a compressor which was retro fitted to the existing system and this combination produced very crisp cold air, a huge improvement. I have come to the conclusion that the old compressors are inefficient and the modern new ones are the answer to an aging ac system that we have. One of my friends replaced his compressor in a 2L air cooled VW bus with a smaller modern one and it transformed his ac.
> With the T3, the engine compressor bracket would have to be modified and new hose connectors installed to suit the compressor used. All other components remain.
> If you can get a new modern compressor that bolts straight on the existing bracket then that would be the major part of the ac upgrade. The remaining things are to get new fittings on the hoses to connect to the compressor, new TX valve and receiver-drier.
> I would use Hose Masters/Enzed or similar to crimp on new o-ring connectors. Any decrease of length as the result of cutting off the old fittings can be made up by using longer Al tails on the new fittings, all available off the shelf. The rest of the components in the system are re-used i.e., condenser, evaporator, thermostat, pressure switch and hoses.
> I would then present the completed system to an ac specialist and ask them to do a re-gas. Make sure that the system is flushed to remove any R12, oil and contaminants. Have a pressure test using Nitrogen gas and as well, a vacuum leak down test. Make sure they use extra oil because of the longer hoses in the syncro. They will probably inject a UV sensitive dye with the R134A for leak checking post re-gas. It would be a good idea to return to them after approx. 600km with good use of the ac for a further leak test.
> My ac has remained very cold now some 3yrs later. However one would expect a slow reduction of efficiency after 5yrs or so due to the slow molecular diffusion of the gas through the long rubber hoses and seal leaks.
> For the moment I am keeping cool.
> Regards
> Yurik      21/11/2008
> Â
> Â
> Â
> This leaves me then with my original questions the subject of this post, if anyone has something specific to add along those lines, I'd much appreciate it asap. TIA.
> Â
> Â
> Â
> Ken unless you are putting an air curtain behind the driver or an additional evaporator in the rear, save your money. The evaporator size and fan capacity are just insufficient for a five metre long box. If the in dash thing would have worked VW would have done it. Instead they put a massive duct from rear to front. I guess your lucky as from what I understand you probably won't have rear passengers which to me says go the plastic curtain. Greg E
> Â
> Â
> All,
> Â
> I am about to embark on the refurbishment of the erm ... "much loved" Prestige AC system in my syncro. Touch wood. Wish me luck.
> Â
> Please see the attached files re the new Zexel compressor that will be swapped in for the 20yo Sanden 709 as well as the pdf fluid volume spec files for Vanagon AC systems. I suspect these Vanagon fluid volumes are not relevant to our Prestige AC system, merely notable. Agreed?
> Â
> One thing I am unsure of is, aside from the refrigerant oil already in the new compressor, how much extra total volume of same refrigerant oil is added to the system for other components during refurbishment?
> Â
> Putting the question another way, ignoring the refrigerant oil volume included in any new compressor, how much extra total volume of same refrigerant oil was added to the system for other components during assembly as specified for the original Oz Prestige AC system in our vans? TIA.
> Â
> Â
> KenÂ
> Â
> Â
> Â
> Â
> Â
> Â
Try moving the thermostat.
That sounds like a poor air flow design. It's cooling where the thermostat is, but not flowing properely into the passenger area if you can understand that.
> cold again it has frozen up, so go hotter. Usually you can����hear the
> > All,
> other ok.
> > Cheers.
> > From: hartis@...
> installed at at the air exit side. I have taken that thing out as it����
> (to me) doesn��������t serve any other purpose then obstructing the airflow.
> Worx better now.���� Hartmut
> other syncros, don't know though what brand of install they are.����
> had. Greg E
> > Greg
> the NW.
> > Yurik
> temp.����There is just not enough air coming out to cool the cabin. Mark
> was telling me at the dotvw that he had a rear evap fitted.����Does
> > Greg,
> > Ken,
> replaced and this improved the cooling significantly.���� Later when I did
> the Subaru engine conversion the new engine (2003)���� came with a
> combination produced very crisp cold air, a huge improvement.���� I have
> modern new ones are the answer to an aging ac system that we have.���� One
> and new hose connectors installed to suit the compressor used.���� All
> existing bracket then that would be the major part of the ac upgrade.����
> hoses.
> leaks.
> > Regards
> > Yurik������������������������ 21/11/2008
> > Cheers.
> a massive duct from����rear to front. I guess your lucky as from what I
> > All,
> files����for Vanagon AC systems. I suspect these Vanagon fluid volumes are
> included in any new compressor,����how much extra total volume of same
> refrigerant oil was added to the system for other components����during
> vans? TIA.
> > Cheers.
> > Ken����
Whilst on the subject of Prestige, I would remind anyone who has one that the Prestige supplied mounting for the compressor is something normally found only on heavy earthmoving equipment.
It is extremely crude and has the capability of breaking off the crankcase mounting boss at the left rear of the crankcase.  This had happened to mine before I bought it.
I was alerted to the problem when I noticed that the compressor pulley did not align with the crankshaft pulley.  I dismantled it to find why and discovered that the rear left boss had been broken off.
Use the original VW mounting!
,___
Ken,  had a check on that a/c of mine, let it run at 3thou for 10 mins , all it did was 8*C and that at today’s 20*C. So yours should be much better, probably is. I measured mine with a cheap Jaycar Digitech Multimeter, what instrument are you using ?
Hartmut
Sent: Friday, 25 November 2011 10:33 PM
Yeah thanks for that Hartmut ... be great.
Any others? TIA.
Date: Fri, 25 Nov 2011 20:25:28 +1100
Will check tomorrow, Ken.
Sent: Friday, 25 November 2011 8:18 PM
All,
Hi Eddie, do you just keep the control knob all the way to cold? If so it could be freezing up. That is assuming that the second knob prestige put on the dash is a thermostat. If you want to try the adjustment as I previously described, start with the knob closer to the hot end and gradually turn it down noting the temp it cuts in and out. Is yours a bit asthmatic? Might be worth checking out the vent openings. Greg E
Sent: Saturday, 26 November 2011 11:07 AM
Subject: Re: [Syncro_T3_Australia] Re: Prestige AC system
go warm and then
> > All,
> other ok.
> > Cheers.
> > To:
ymailto="mailto:Syncro_T3_Australia@yahoogroups.com">Syncro_T3_Australia@yahoogroups.com
> > From: hartis@...
> > To:
href="mailto:Syncro_T3_Australia@yahoogroups.com" ymailto="mailto:Syncro_T3_Australia@yahoogroups.com">Syncro_T3_Australia@yahoogroups.com
> had. Greg E
> > To:
> > Greg
> the NW.
> > Yurik
> > From:Ken
class="mark">Garratt <unclekenz@...>
> > Greg,
> > Ken,
id="misspell-45" class="mark">XT valve
> other components
remain.
> hoses.
> R12, oil and
> leaks.
> > Regards
> > Yurik       21/11/2008
Yurik.
> > Cheers.
class="mark">VW would have done it. Instead they put
> > All,
> vans? TIA.
> > Cheers.
Yahoo! Groups Links
<*> Your email settings:
    (Yahoo! ID required)
Hartmut,
Interesting. My static test was the same .... 8 deg C outside the left vent. My "instrument" was a glass thermometer found hanging up in my garage. Good enough?
I'll do another test while driving. Some more results from others would be appreciated.
The thought of 3-5 deg C is compelling. But realistic? Only more results coming in will give us a clue. Please?
Date: Sat, 26 Nov 2011 13:17:24 +1100
Hartmut
Any others? TIA.
All,
Yes Ken, 3-5 *C should achievable . When I installed a Prestige unit into my first Syncro in 1988 it spewed snowflakes at defrost cycle, always reminded us of white Christmas....very funny.
Your glass thermometer should be perfect as long as is in good shape.
Hartmut  (not going anywhere in this weather, 92% RH and raining, I dislike the Trakka getting wet)
Sent: Saturday, 26 November 2011 1:53 PM
Hartmut,
Hartmut
Any others? TIA.
All,
Oh for the days of r12 (and sight glasses that work)again Hart. The last time I saw that was when I was in Vietnam. The plane was an ex Russian illusion that was too old for service for them but not for the Vietnamese, it was painted with a brush and you could see the belts hanging out of the tyres. Anyway we sit down still in massive humidity and heat, they close the doors and start the engines then the snow starts to spew from over head. All flight the overhead lockers are swinging like they are about to fall on our heads. Even though we were as cool as cucumbers I still had my heart in my mouth the whole flight. Greg E
> Hartmut,
> enough?
> appreciated.
> From: hartis@...
> it did was 8*C and that at today's 20*C. So yours should be much better,
> Hartmut
> Any others? TIA.
> From: hartis@...
> Greg,
> Prestige system?
> All,
Greg,  you are so right. My a/c is charged with R12 ,good old panther p... ,and not more harmful than the new stuff. But we had to have the New because the patents on the  R  products had run out , so to keep the royalties coming they ‘invented’  the New.
We have to meet up and exchange more of those stories before they are forgotten or we are getting on too much. ..Remind me to part with the flight detail in a Russian 1000hp single engine Antonov Biplane, comes close to what you experienced. Or the 8hr flight with Air Zimbabwe that’s a story on its own... Btw where do you park your Syncro ??
Hartmut
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of gregespo73
Sent: Sunday, 27 November 2011 9:30 AM
> Hartmut,
> enough?
> appreciated.
> From: hartis@...
> Hartmut
> Any others? TIA.
> From: hartis@...
> Greg,
> Prestige system?
> All,
Are you saying what's seen at the sight glass cannot be relied on or is meaningless?
Date: Sat, 26 Nov 2011 22:30:20 +0000
> Hartmut,
> enough?
> appreciated.
> From: hartis@...
> Hartmut
> Any others? TIA.
> From: hartis@...
> Greg,
> Prestige system?
> All,
Hi Hart, sadly my syncro sits in the driveway soaking up the Melbourne rain. I need to raise the roof on my garage to fit the 2.2metre tall bus in. I just don't have the time to take on such a project, at the moment I need a special leave pass to mow the lawn. One day I will get up to your neck of the woods and share near death flight experiences with you. I will remind you about the antonov and you can remind me about the flight I had in the Nepal Himalaya (should exit doors be loose in flight?). Greg E
P.S. I'll bring the beer, the vitrifrigo works better than the A/C.
Sent: Sunday, 27 November 2011 1:00 PM
Hartmut
> Hartmut,
> enough?
> appreciated.
> From: hartis@...
> Hartmut
> Any others? TIA.
> From: hartis@...
> Greg,
> Prestige system?
> All,
Ken it is my understanding that the sight glass only works with r12. Back when we were working with r12 no one cared about capacity too much you just put the gas in through the low side untill the bubbles stopped. When r134a came out they told us it does not work with the new gas. I took that as gosple and measured every gram since. I fact most modern cars don't have sight glasses at all, but do have a sticker under the bonnet telling you how many grams the system takes. The guys who do this stuff every day might have some way of using the sight glass as an indicator during filling, but I think they now rely on pressures and quantity. Greg E
Sent: Sunday, 27 November 2011 4:01 PM
> Hartmut,
> enough?
> appreciated.
> From: hartis@...
> Hartmut
> Any others? TIA.
> From: hartis@...
> Greg,
> Prestige system?
> All,
Ken / Greg , Learning the trade in the Safrican bundu we never took much notice of sight glasses and the like, when doing a fridge we charged very slowly thru the low pressure side until the return line towards the compressor started to ice up. By releasing a tiny bit of gas (those were the times when we used the gas to blow clean the dusty condensers !!) we watched the ice melt back into the fridge.
Bingo, welding up the system ,check for leaks and write the invoice.
My Syncro a/c I did it the same way charged slowly at 3000rpm until the return got nicely cool. End of story. When I bought the beast the seller mentioned that the a/c could not be fixed.... I pulled the compressor to bits , it had seized, put it back together and it works ever since.
These days everybody throws the rule book at you and by being over philosophical not much gets archived any more.
I better stop.... Hartis
Sent: Sunday, 27 November 2011 4:34 PM
> Hartmut,
> enough?
> appreciated.
> From: hartis@...
> Hartmut
> Any others? TIA.
> From: hartis@...
> Greg,
> Prestige system?
> All,
Greg & Hartmut,
Interesting that my AC guy did, among other things, monitor his gauges AND the sight glass during the fill/pressure process. He also did explain to me how to interpret what I was seeing/likely to see in it, such functionality then seeming to be at variance with what you and Hartmut are saying about its usefulness. A conundrum then eh.
I've always felt the service specs/quantities for a Prestige system have probably been lost over time or never documented. I do know the AC guy referenced his data book and as I expected, he came up empty handed. So with no official Prestige AC spec sheet, does that mean then he would be left with no alternative but to "best guess" what fluid/gas/pressure quantities to utilise as well as the best methodology to employ, perhaps even not dissimilar to Hartmuts?
If I'm not achieving the low temps that those here believe are attainable, best then it's back to the drawing board for me? Assuming (yet to be re-tested) my system is now no longer leaking as it once was (looks aok still at the sight glass!), does it in fact then come down to seeking out THE optimum ratio of fluid/gas/pressure and a better methodology to achieve lower temps? If so, any ideas/suggestions then on what steps I could now pursue? By the way, unlike what Yurik said to do, he chose not to replace the TX valve. Worth pursuing? TIA.
Date: Sat, 26 Nov 2011 21:33:48 -0800
> Hartmut,
> enough?
> appreciated.
> From: hartis@...
> Hartmut
> Any others? TIA.
> From: hartis@...
> Greg,
> Prestige system?
> All,
Greg Thomas (not Geoff Thomas) (02) 9774 4556 or (02) 9774 4133
Auto-Frost
1/9 Works Place, Milperra
BenC
> BenC
> > From: gregespo73@
> E
> NW.Yurik From:
> > From: gregespo73@
> notable. Agreed?
Hi Les and other Prestige A/C people. I am up to fitting the original VW A/C bracket at the moment and having difficulty fixing the rear RH mounting bolt because the pipe that leads into the intake air distriutor is just over the top of the bolt hole.
Have others had this issue and is the only fix to remove the pipe altogether? Greg
--- In Syncroe_T3_Australia@yahoogroups.com, "Les Harris" <leslieharris@...> wrote:
> before I bought it.
> ,___
